Removeing Pad Material From Cnc Backings
Matt Vandart
Chuck 'em in, turn it on to 180 or so and by the time it's up to temperature the bond should be broken enough to pull out. If not, give them another minute or two (Y)
Remember the backings/pad material will be hot!
If they're not glued in and just pressed of course then you can just pull them out
