Advice Needed On Stem Selection!
murph82
Hi
Thought I would introduce myself. I'm kevin, 28, recently started riding again after dropping it for 7 years or so. Enjoyed street riding mostly, was kind of ok but never had in me to go massive! Had a pashley 26mhz with u.s.e tfi''s which was one of THE framesets to have back then!
Anyway, trying to get back on now. Have picked up a fairly good spec bike secondhand from different places, Koxx LB 1065, dmr/tryall rear wheel, sun front disc wheel, hs33's, echo barand stem.
BUT.....with current bar and stem it feels a bit flat, think what I have is probably 5 deg and 100mm, I was thinking 25 deg+ and 120mm +. I'm 5'10.........any opinions? direction would be appreciated!
Have registered here to be able to find out how things work now and what the vibe is!
Thanks
Kevin
  • 1 month later...
Get a 110x10 or 120x20ish stem on there, should be fine, you'll benefit from a nice set of risers too. Oh and welcome back to the sport :)
are the trials risers the same as normal mtb risers? only had flat bars when i used to ride? was thinking about maybe using a short mod stem with flat bar i have, might look a bit odd but could put the bars in a similar place, i like the look of the position on the koxx sky bikes??
thanks for suggestion
No, trials riser bars tend to have more up and back sweep on them. Making standard handlebars look rather flat by comparison.
I used onza carbons as a transition from flat bars then recently i've moved onto monty's and now viz bars.
Flat bars aren't very nice, i would ditch them if i were you. on a 1065 a really long stem will see you quite far over the front of the bike, which can feel a little unnatural. At 5'10" i'd be inclined to go for something between 100 and 120mm with maybe 10-15 degrees of rise. Then a nice set of riser bars to compliment it.
Ok mate, thanks for your opinion, part of the length was to give a little more reach, feels a touch short, to be honest I bought the frame second hand because it was cheap and looked a better geo than the martin hawyes rep i had so could probably just do with a longer frame! I'll look into gettin some bars. I used to ride downhill bars on my pashley years ago but never got especially good so wanted to get a more pure set up this time round, i'll give it a go! I just want to up the front end a lot as the bike feels very flat, want to replicate the look of the koxx sky bikes!
Cheers
Cheers
The koxx sky bikes have a very high front end to compensate for the high bottom bracket though. The levelboss will have a flat bottom bracket, so putting a similar stem as designed for the sky frames will result in the balance point on the back wheel being fairly sluggish on your koxx.
