Rubbish Brake Bite
trialsmax04
Pretty pissed off at the moment. My rear brake hasnt been too great for a while now, so ive just re ground the rim with a medium sharp grind, fresh bleed (water) and re-set up the pads.
Crap bite and poor sound.
Any ideas guys?
Heatsink mk2 backings and coust pads,
Atoms Rim
HS33
No booster but built in one on my HIFI frame.
Cheers guys
max
Any ideas guys?
Atoms Rim
HS33
Cheers guys
max
Make sure the pads are clean, And properly lined up.
Best to check the flex of the frame, even with a booster my frame flexes a bit.
Cheers guys.
Im not that silly i can set up a brake reasonably well!
To be quite honnest im not a huge fan of the coust pads since the originals i tried, i swear there different. Anyhow, its working okay now after i sanded my pads 100% flat. Next time i need new pads its going to be some TNN Baleys....
Sand the pads flat. You're going to lose material now but if they're wearing at an angle you'll lose more later with a shite brake until they're dead.
I use a belt sander, but if you're VERY careful you can press them onto the flat surface of a spinning angle grinder disc. This is pretty dangerous though, pads sometimes fly out your hand, you've got a spinning disc next to your arm, if you press for too long instead of short sharp presses you'll melt your pads.
Also, make sure the material is glued into the backings. Glueing my phat material made a massive amount of difference compared to just pressed in.
