Tyre Fit Problem
Dušan
Hey i have a strange problems... i cant fit the tyre on a Tryall 26 inch rim... but i cant even put it down..... wtf?? i had a maxxix downhill tyre and it took me like 2 hours to take it down now i have tryall stiky on it cant put it on but f*ck i cant even put i down! :( when i had the tryall stiky on my echo TR rim i could easily put it down just using my hands.... so i guess iam stupid or the tryall rim.... or both what i think is the most possible thing
Check out tartys tyre fitting guide :)
Basically pull the bead off the rim wall into the centre of the rim when youre pulling the last bit of bead on.
hah watched that already... didnt find it very helpful my tyre is like 10 times thougher than adams :DDand i think i already done something to my finger while doing it... btw i still havent done it
grow some muscles! na just joking, i use a metal tyre thing, when one side of the tyre is on the rim put it on top the rim and under the tyre and push down then get another one while its in there and eventually the majority of the tyre is on.
probely completely different for what u mean :giggle:
i have this problem with my tt undrilled rim and my rain king tyre but its not impossible, if tyre levers break wedge a big flat head screw driver in to start it off and then work from there with normal tyre levers, does the trick for me :turned:
yea i tried it also with screw drivers about 6 pinches in tube :giggle: but that might also be cause i was doing it really hard so i didnt care about how am i doing or what can i damage...
Edited by Dušan
