trials owns Posted August 8, 2010 Report Share Posted August 8, 2010 (edited) hi, i want to cut down my hosing on my hs33 for the front because its to long, does the long bit of hosing connect with a barbed hose end at the brake cylinders or lever? right, so if it does how do you put the barbed hose end in? it says on tarty with a mallet and two pieces of wood. or is it connecting on the main hosing with a shroud nut and a olive on the end of the hosing? cheers Edited August 8, 2010 by trials owns Quote Link to comment Share on other sites More sharing options...
Sam Styles Posted August 8, 2010 Report Share Posted August 8, 2010 if you are on about cutting the main hose down (lever to brake) then its shoud nut and olives... you just need a new olive to slide on the end of the cut hose, and when you tighten it back up into the brake or lever, the olive compresses onto the pipe Quote Link to comment Share on other sites More sharing options...
Mark W Posted August 8, 2010 Report Share Posted August 8, 2010 Assuming you haven't changed it yourself, you should have a shroud nut and olive setup on there at the moment. It's pretty easy to check - you can take the hose out of the lever and check the end of it without losing any fluid (if you're careful!). All you should really need is just a new olive. Again, if you're careful, you should be able to cut the hose down without losing any fluid too, meaning no need to bleed Quote Link to comment Share on other sites More sharing options...
trials owns Posted August 8, 2010 Author Report Share Posted August 8, 2010 cheers lads! me being carefull i might go back to a water bleed. any ideas what i should cut it with? i suppose scissors will do the job. i might get a hose cutter but not sure where to buy one. Quote Link to comment Share on other sites More sharing options...
Sam Styles Posted August 8, 2010 Report Share Posted August 8, 2010 stanley knife blade... i take it out the knife and hold it in my fingers... i find it easyer to control and gives a cleaner cut Quote Link to comment Share on other sites More sharing options...
trials owns Posted August 8, 2010 Author Report Share Posted August 8, 2010 stanley knife blade... i take it out the knife and hold it in my fingers... i find it easyer to control and gives a cleaner cut ah yeah i didn't think about that think my dads got some blades somewhere, thanks. Quote Link to comment Share on other sites More sharing options...
Sam Styles Posted August 8, 2010 Report Share Posted August 8, 2010 no worries... good luck with not spilling any fluid Quote Link to comment Share on other sites More sharing options...
