Reset Titanium Bb
crispyboy
Hello everyone
Ive had my reset bb for about 6 months now and it has started to make a cracking and creaking noise it works fine just make this horrible sound when you do a full rotation
of the cranks.
Its not loose as ive done it up really tight and have recently check it.
Has anyone had this problem with a reset or any bb ?
Anyways of curring this ?
As its an expensive bb and it hasent really lasted long for the price
It's expensive because it's titanium, not because it's going to last for forever.
Anyways - re-grease everything. If there's still a noise then, it could be that one of the bearings is blown. If it is, the Reset uses the same bearings as the Try-All BBs so you can use 1 x 7mm bearing in the non-drive side and a pair of 7mm bearings on the drive side.
