Sam Styles Posted August 6, 2010 Report Share Posted August 6, 2010 okay guys, i made my self a new crossover pipe the other week, and i only got round to fitting it last night. i followed the instructions on the magura website, used a vice, the correct clamps, and a hammer... but i squeeked my brake a min ago and there is water trickling out of the tube where it fits onto the barb why is it leaking? anyone else made a crossover before? Quote Link to comment Share on other sites More sharing options...
josh barker Posted August 6, 2010 Report Share Posted August 6, 2010 happend to me, i find it better to use brand spanking new hose and fittings, just seems better to me. make sure the barb fitting goes exactly square in, if not it will leak. you can use a light lube on the hose+fitting such as 3 in 1. dont know why yours is leaking, if you have followed the magura vid you must be ok? Quote Link to comment Share on other sites More sharing options...
Sam Styles Posted August 6, 2010 Author Report Share Posted August 6, 2010 happend to me, i find it better to use brand spanking new hose and fittings, just seems better to me. make sure the barb fitting goes exactly square in, if not it will leak. you can use a light lube on the hose+fitting such as 3 in 1. dont know why yours is leaking, if you have followed the magura vid you must be ok? i used new pipe and fitting :L ima have another go at it now. Quote Link to comment Share on other sites More sharing options...
josh barker Posted August 6, 2010 Report Share Posted August 6, 2010 i used new pipe and fitting :L ima have another go at it now. i had some left over parts of pipe so i just practiced joining the fittings. practice makes perfect Quote Link to comment Share on other sites More sharing options...
Sam Styles Posted August 6, 2010 Author Report Share Posted August 6, 2010 i had some left over parts of pipe so i just practiced joining the fittings. practice makes perfect i got 1.5 metres of the stuff to play with lol Quote Link to comment Share on other sites More sharing options...
psycholist Posted August 6, 2010 Report Share Posted August 6, 2010 Check the barbs on the ends of the crossover for damage - if you put notches into the edges of the barbs while cutting the old hose off them you've probably created a path for fluid to leak out. Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted August 6, 2010 Report Share Posted August 6, 2010 I'll tell you exactly why it's leaking. You made it yourself. 1 Quote Link to comment Share on other sites More sharing options...
dirt jumper jake Posted August 6, 2010 Report Share Posted August 6, 2010 Did you heat up the end of the hose in boiling water ? thats what i used to do when i had plastic hoses and it worked at treat first time Quote Link to comment Share on other sites More sharing options...
Simpson Posted August 6, 2010 Report Share Posted August 6, 2010 Your doing it wrong.... lol Quote Link to comment Share on other sites More sharing options...
Sam Styles Posted August 6, 2010 Author Report Share Posted August 6, 2010 I'll tell you exactly why it's leaking. You made it yourself. i knew there would be at least 1 smart twat that would say that ive got it sorted now anyways, cheers guys. i made another one, the same way i did before, and its worked perfect Quote Link to comment Share on other sites More sharing options...
