saracen1989 Posted August 5, 2010 Report Share Posted August 5, 2010 How would an 18 teeth freewheel on the front and 18 teeth fixed sprocket on the back run? would it work? Quote Link to comment Share on other sites More sharing options...
Sam Styles Posted August 5, 2010 Report Share Posted August 5, 2010 it would be shit Quote Link to comment Share on other sites More sharing options...
N.Wood Posted August 5, 2010 Report Share Posted August 5, 2010 It would work as in the wheel would go round when you pedal, but it would be way too easy/light gearing. Ideally you'd want 22:18 or 18:15 depending on what you're after. EDIT: Sorry thats for stock. Mod will be 18:12 ideally. Quote Link to comment Share on other sites More sharing options...
saracen1989 Posted August 5, 2010 Author Report Share Posted August 5, 2010 what about 18 on front and 12 on the rear any bettter Quote Link to comment Share on other sites More sharing options...
Sam Styles Posted August 5, 2010 Report Share Posted August 5, 2010 what about 18 on front and 12 on the rear any bettter thats the standard mod gearing.. i have it. thats what you wanna go for Quote Link to comment Share on other sites More sharing options...
trials owns Posted August 5, 2010 Report Share Posted August 5, 2010 (edited) what about 18 on front and 12 on the rear any bettter yep that what most 20" rider use but not for 26" Edited August 5, 2010 by trials owns Quote Link to comment Share on other sites More sharing options...
saracen1989 Posted August 5, 2010 Author Report Share Posted August 5, 2010 yeh i do ride mod whats rear sprockets do u guys reckomend? Quote Link to comment Share on other sites More sharing options...
Sam Styles Posted August 5, 2010 Report Share Posted August 5, 2010 yeh i do ride mod whats rear sprockets do u guys reckomend? echo tr screw on ( if you have a screw on hub) Quote Link to comment Share on other sites More sharing options...
saracen1989 Posted August 5, 2010 Author Report Share Posted August 5, 2010 echo tr screw on ( if you have a screw on hub) Yerh ive got a tryall hub allows screw on sprocket/freewheel Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted August 5, 2010 Report Share Posted August 5, 2010 Echo tr or maybe try all. be warned though put grease on the threads first or you will never get that sprocket back of a try all hub. 1 Quote Link to comment Share on other sites More sharing options...
saracen1989 Posted August 5, 2010 Author Report Share Posted August 5, 2010 Echo tr or maybe try all. be warned though put grease on the threads first or you will never get that sprocket back of a try all hub. Cheers for the advice Quote Link to comment Share on other sites More sharing options...
