Matt Vandart Posted August 5, 2010 Report Share Posted August 5, 2010 Right dudes, I got an Echo control and with 18/15 the chain is too long or too short and the maggie mounts wont line up. Also the axle bolts are pretty much hanging of the back of the drop out. To counter this I'm gonna either go up one tooth or down one tooth. Any ideas which would be betterer: 18/14 or 18/16 Thanks Quote Link to comment Share on other sites More sharing options...
isitafox Posted August 5, 2010 Report Share Posted August 5, 2010 Have you thought of getting a half link in the chain? If not then I think 18-16 would be better! Quote Link to comment Share on other sites More sharing options...
Krisboats Posted August 5, 2010 Report Share Posted August 5, 2010 18:16 or 16:13 Quote Link to comment Share on other sites More sharing options...
raoulduke Posted August 5, 2010 Report Share Posted August 5, 2010 I've noticed a few people on this forum with a similar problem, and it's putting me off horizontal dropouts. From what I know after 18-15 most people use 18-16 so I guess that would be the best way to go, but it would be good to hear from somebody running 18-14, I imagine it would be good for street/BMX style riding. Anyway good luck, I hope you get it sorted. RD Quote Link to comment Share on other sites More sharing options...
forteh Posted August 5, 2010 Report Share Posted August 5, 2010 Why not fit a spoke tensioner? I made a semi sprung fixed tensioner from a small aluminium bracket and length of plastic (ultra high molecular weight polyethylene to be precise ) cut as a chain guide; the natural flex in the guide keeps tension really well. Altering the rear teeth is a pretty drastic change to the ratio, this can be minimised by changing crank length though, if you drop to 18:16 running 165 cranks instead of 175 will keep the gearing pretty close. Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted August 5, 2010 Author Report Share Posted August 5, 2010 I did think of both these things dude , but I aint got any 165mm any more, lol I have got some 170mm though Quote Link to comment Share on other sites More sharing options...
forteh Posted August 5, 2010 Report Share Posted August 5, 2010 I did think of both these things dude , but I aint got any 165mm any more, lol I have got some 170mm though If youre running burns I have some 165s spare, square taper only Im afaid Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted August 5, 2010 Author Report Share Posted August 5, 2010 thansk for the offer dude but it's ffw only these days Quote Link to comment Share on other sites More sharing options...
N.Wood Posted August 5, 2010 Report Share Posted August 5, 2010 Its dogshit... The one thing I dislike about my Control. I ran a halflink which solved all my problems till about a month later and it snapped in half rendering my knuckles free from skin. Now I whack a brand new chain on, wait for it to stretch, then theres just about enough room to take a link out and slam the wheel towards the frame. Just gotta watch out for the tyre clearance. This is on 18:15 with trialtech chain, Echo SL freewheel Echo ti cog, Hole rim and Rain King. Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted August 5, 2010 Author Report Share Posted August 5, 2010 How do you wait for it to stretch? Quote Link to comment Share on other sites More sharing options...
rab shropshire Posted August 5, 2010 Report Share Posted August 5, 2010 The 09 control is designed around 18-16 gearing i get round it by running 18-15 with a single half link and it has been plenty strong Quote Link to comment Share on other sites More sharing options...
forteh Posted August 5, 2010 Report Share Posted August 5, 2010 How do you wait for it to stretch? Hang it up from a roof beam and hang a long weight from the end, tadaa! one stretched chain Quote Link to comment Share on other sites More sharing options...
Ross McArthur Posted August 5, 2010 Report Share Posted August 5, 2010 It'll stretch if you stare at it for long enough... If only. I think he means he runs the chain too long, then after a good few rides it will have stretched then he is able to slam it in after taking out a link? Hang it up from a roof beam and hang a long weight from the end, tadaa! one stretched chain Ha ha, a long weight? Almost as good as tartan paint. Quote Link to comment Share on other sites More sharing options...
Mark W Posted August 5, 2010 Report Share Posted August 5, 2010 If it's too tight when the chain's brand new, you can put a few links from your old chain in the new chain which will help give it a tiny bit more length. I've had to do it on my Inspired with my ratio to get it to sit in the dropouts properly and it seems to work fine... Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted August 5, 2010 Author Report Share Posted August 5, 2010 All good replies. I'll get a new chain and hang it from my sky hook with a long weight on it and paint my walls tartan while it stretches. I think i'll go with 18/16 Thanks dudes. Quote Link to comment Share on other sites More sharing options...
