Rusevelt Posted August 2, 2010 Report Share Posted August 2, 2010 Don't know if this idea has been tried before but the grip is amazing. I basically used two wide strips of halford grip tape (very course grip tape) and cut the shape of the pedal, carefully drilled holes where the pins would sit and just stuck it on with the aid of superglue ( Quote Link to comment Share on other sites More sharing options...
liam n Posted August 2, 2010 Report Share Posted August 2, 2010 looks like a quite good idea but surely u'd be better buying pedals with adjustable pins and gett longer pins (8mm instead of 5mm) or grippy shoes Quote Link to comment Share on other sites More sharing options...
stya_bear Posted August 2, 2010 Report Share Posted August 2, 2010 i think it look awesome! Real neat Quote Link to comment Share on other sites More sharing options...
PeanuckleJive Posted August 2, 2010 Report Share Posted August 2, 2010 I have no idea what they were, but my old platforms had a little bit of griptape on them in the middle, wasn't really enough to make a noticeable difference but it's a good idea Ride them for a bit and see how they work out, there might be a reason nobody does it. But if it works for you, then fair play Quote Link to comment Share on other sites More sharing options...
theom Posted August 2, 2010 Report Share Posted August 2, 2010 looks like a quite good idea but surely u'd be better buying pedals with adjustable pins and gett longer pins (8mm instead of 5mm) or grippy shoes Nice shindig Quote Link to comment Share on other sites More sharing options...
Matt Burrows Posted August 3, 2010 Report Share Posted August 3, 2010 Yeah I've been doing it for years on mine, really helps in a muddy comp! Quote Link to comment Share on other sites More sharing options...
Mark W Posted August 3, 2010 Report Share Posted August 3, 2010 Fly Ruben pedals come with some custom-cut griptape as standard, but it's worth bearing in mind if you ride when it's wet it wears out pretty quickly (Just ask skateboarders...). Quote Link to comment Share on other sites More sharing options...
craigjames Posted August 3, 2010 Report Share Posted August 3, 2010 Funn Soljam pedals have a small section of grip tape in the centre of the platform, they've been out for fair few years now. Never tried any, could be ok. Matt surely with muddy comps they get gooed up with mud making the grip tape useless? Quote Link to comment Share on other sites More sharing options...
liam n Posted August 3, 2010 Report Share Posted August 3, 2010 Nice shindig when i decided to do this i was working on the idea. the grippier the pedal the less i'd get shin dig Quote Link to comment Share on other sites More sharing options...
Rusevelt Posted August 3, 2010 Author Report Share Posted August 3, 2010 looks like a quite good idea but surely u'd be better buying pedals with adjustable pins and gett longer pins (8mm instead of 5mm) or grippy shoes The idea was generally a cheap alternative for those who afford, or justify buying FiveTen shoes, or better pedals. My mate tony was complaining about being able to twist his feet the platform surface, hense the idea of the grip tape. Sure it will wear down over time, and is practically useless in wet condition, but its cheap and fairly easy to do. Just be sure to to use as much of the tape as you can as opposed to just cutting little pieces and just sticking them on because it doesn't work. I found that out the hard way with my first attempt. Quote Link to comment Share on other sites More sharing options...
STEVE-0 Posted August 3, 2010 Report Share Posted August 3, 2010 I had a go on Mike Singleton's Phase that had exactly the same, I did feel a lot more grip although it was bone dry weather. Quote Link to comment Share on other sites More sharing options...
