Juan Manuel Posted August 1, 2010 Report Share Posted August 1, 2010 I'm buying a new frame as well as a booster (Magura) . The Echo SL booster looks nice BUT it's made from 6061 alloy. I know there are some others from 7075 alloys and carbon fibre (which are not in stock in the shop where I'm buying ) . Does anybody has one Echo SL booster?? What's your personal opinion?? Quote Link to comment Share on other sites More sharing options...
Shaun H Posted August 1, 2010 Report Share Posted August 1, 2010 There's less than 5% difference in stiffness between 6061 and 7075. The difference is mostly in the materials' strength and corrosion resistance. Quote Link to comment Share on other sites More sharing options...
anusthegreat Posted August 1, 2010 Report Share Posted August 1, 2010 I heard some of my mates complained about 4-bolt boosters don't make such a big difference in braking power like 2-bolt ones. Also, it depends on a frame, if it's stiff or not. My HS-33 on the rear used to unclamp the frame too much so I had to obtain one of 4-b boosters from a local Russian manufacturer. Somehow, it's way better now, but since not perfect. People say it's better to try different boosters out before buying one. Mostly, people use boosters to protect magura's hose from damaging, if they have a decent frame, too. This is my setup and it's running pretty decent actually. Quote Link to comment Share on other sites More sharing options...
liam1992 Posted August 2, 2010 Report Share Posted August 2, 2010 I have a echo sl 2 bolt booster works pretty good dosent flex but my rim dose Quote Link to comment Share on other sites More sharing options...
Luke Dunstan Posted August 2, 2010 Report Share Posted August 2, 2010 (edited) I have a echo sl 2 bolt booster works pretty good dosent flex but my rim dose I had one until yesterday, it was sooo flexxy, It made very little difference. It looks fancy, but it can't perform, so basically its useless. Just got the Tensile this morning, Stiffer than a frozen stiff thing. EDIT: 4-bolt Edited August 2, 2010 by xDUNSTANx Quote Link to comment Share on other sites More sharing options...
Juan Manuel Posted August 3, 2010 Author Report Share Posted August 3, 2010 Well I suppose going for the Echo Sl 2-bolt booster is my best bet. Mostly, people use boosters to protect magura's hose from damaging Yes!!! By the way nice setup I had one until yesterday, it was sooo flexxy, It made very little difference. It looks fancy, but it can't perform, so basically its useless. Just got the Tensile this morning, Stiffer than a frozen stiff thing. EDIT: 4-bolt The booster was new? Did you set it up correctly? Wich frame where you using it with? Quote Link to comment Share on other sites More sharing options...
Krisboats Posted August 3, 2010 Report Share Posted August 3, 2010 I have a echo sl 2 bolt booster works pretty good dosent flex but my rim dose You notice your rim flexing when the brake is applied? Quote Link to comment Share on other sites More sharing options...
Luke Dunstan Posted August 3, 2010 Report Share Posted August 3, 2010 Well I suppose going for the Echo Sl 2-bolt booster is my best bet. Yes!!! By the way nice setup The booster was new? Did you set it up correctly? Wich frame where you using it with? Had it on my Zhi Z3. Granted the frame is fairly flexy but the booster did barely anything, The tensile one is solid. Quote Link to comment Share on other sites More sharing options...
Juan Manuel Posted August 3, 2010 Author Report Share Posted August 3, 2010 Had it on my Zhi Z3. Granted the frame is fairly flexy but the booster did barely anything, The tensile one is solid. I can't get tensile products in the dealer where I'm buying I suppose I should go for the Echo and try it. I can always sell it anyways Quote Link to comment Share on other sites More sharing options...
Mark W Posted August 3, 2010 Report Share Posted August 3, 2010 The Tensile's stiffer 'cos it's effectively a big ol' horse shoe They're obviously stiff/strong, but they do have a weight penalty as a result of that. The SLs we've put on bikes here seem to have helped quite a bit in terms of reducing flex - if you do have a flexy frame then something that's more heavy duty like the Tensile would be a safer bet, but if it's only a bit of flex you need removing the SL should be fine. Quote Link to comment Share on other sites More sharing options...
PeanuckleJive Posted August 3, 2010 Report Share Posted August 3, 2010 I used to run an RB design 4 bolt, switched to an echo SL 2 bolt and it's just as good, if not better. I can't fault it all, works perfect for me Quote Link to comment Share on other sites More sharing options...
josh barker Posted August 3, 2010 Report Share Posted August 3, 2010 normal trialtech 2 bolt booster, i had a bionic/gu booster on my blade 09 frame. was pretty poor, then got the trialtech and it made loads of difference. trialtech 2 bolt for the win Quote Link to comment Share on other sites More sharing options...
