jamesrs250 Posted August 1, 2010 Report Share Posted August 1, 2010 i started with a onza t bird but could not get the bb out so i bought a monty frame so what i have got is monty frame mission front wheel onza forks h11 Hydraulic Brakes onza rear wheel the first thing im going to change are the onza forks because they are quit heavy and i think because they are the older ones they are a bit small and wobble in the tubing to finish the bike i just need to get a crank and pedal Quote Link to comment Share on other sites More sharing options...
dann2707 Posted August 1, 2010 Report Share Posted August 1, 2010 (edited) Swapping the T-bird, the difference will be amazing mate. Best thing I ever did going from a T-bird to a T-pro. Feels like your actually riding trials and not a bmx. Are you going to end up FFW? Edited August 1, 2010 by dann2707 Quote Link to comment Share on other sites More sharing options...
jamesrs250 Posted August 1, 2010 Author Report Share Posted August 1, 2010 Swapping the T-bird, the difference will be amazing mate. Best thing I ever did going from a T-bird to a T-pro. Feels like your actually riding trials and not a bmx. Are you going to end up FFW? what does FFW mean :$ Quote Link to comment Share on other sites More sharing options...
dann2707 Posted August 1, 2010 Report Share Posted August 1, 2010 Front Freewheel. Quote Link to comment Share on other sites More sharing options...
jamesrs250 Posted August 1, 2010 Author Report Share Posted August 1, 2010 to end up front wheel what does that mean lol Quote Link to comment Share on other sites More sharing options...
dann2707 Posted August 1, 2010 Report Share Posted August 1, 2010 (edited) At the moment your freewheel is located at the back. I meant, do you reckon eventually you will get a front freewheel drivetrain? Sorry for the bad explanation earlier, it's my northern idiolect. Edited August 1, 2010 by dann2707 Quote Link to comment Share on other sites More sharing options...
trials owns Posted August 1, 2010 Report Share Posted August 1, 2010 that looks almost the same as my bike! Quote Link to comment Share on other sites More sharing options...
saracen1989 Posted August 1, 2010 Report Share Posted August 1, 2010 (the first thing im going to change are the onza forks because they are quit heavy and i think because they are the older ones they are a bit small and wobble in the tubing) That wii either be ur headset bearings naffed or the headset in put togeva right Quote Link to comment Share on other sites More sharing options...
anusthegreat Posted August 1, 2010 Report Share Posted August 1, 2010 That's right, Onza forks are too heavy. Get some Urban forks, which are decently priced and weighted. Quote Link to comment Share on other sites More sharing options...
jamesrs250 Posted August 1, 2010 Author Report Share Posted August 1, 2010 At the moment your freewheel is located at the back. I meant, do you reckon eventually you will get a front freewheel drivetrain? Sorry for the bad explanation earlier, it's my northern idiolect. yeah will leave it like it is at the moment. then when i get better on the bike ill change that..i did not even notice (the first thing im going to change are the onza forks because they are quit heavy and i think because they are the older ones they are a bit small and wobble in the tubing) That wii either be ur headset bearings naffed or the headset in put togeva right new head set so i must of put it together wrong Quote Link to comment Share on other sites More sharing options...
saracen1989 Posted August 1, 2010 Report Share Posted August 1, 2010 yeah will leave it like it is at the moment. then when i get better on the bike ill change that..i did not even notice new head set so i must of put it together wrong did u get the ring that sits on the forks an holds ur bearings in? Quote Link to comment Share on other sites More sharing options...
jamesrs250 Posted August 1, 2010 Author Report Share Posted August 1, 2010 did u get the ring that sits on the forks an holds ur bearings in? yeah,,,but on the onza headset the ring was tight around the fork tube..on the new head set the ring was not tight Quote Link to comment Share on other sites More sharing options...
