Rockman Kortz Problem
seaine
hi
can anyone help me with a little problem,the tensioners built in to the frame have jammed and will not move at all i have tried everything,i bought bmx tensioners to pull the wheel but it is not doing the best job to be honest,every time i set the brakes up it is working fine then i put the power the wheel moves then it is back to setting everything up again.
does anyone have any ideas on how i can keep the wheel tight?
