MATRIAL Posted July 28, 2010 Report Share Posted July 28, 2010 hi ,,, i have a problem ,, new bike ,, new brakes ,, new everething ,, and i cant make the MTF brake !,,, this it´s the set up ,,, please tell me posibble solutions ,, hs 33 water bleed ,, long lever , no leeks magura 4 bolt mount OR tnn brake system ( whit booster) OR tnn clamps whit trialtech booster ,, (( you choose i try)) COUST pads ( NEEEEEWWWWW) OR TNN bealey pads MIST frame ( dont flex more than any other frame) and ( and i think here its the problem ) Viz square hole rim ,, ( sharp grind ,) please show me a posible solution ,, cya !! Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted July 28, 2010 Report Share Posted July 28, 2010 Are ,,, your ,,, pads ,,, set ,,, up ,,, square ,,, ? Give ,,, your ,,, hs33 ,,, a ,,, fresh ,,, bleed Quote Link to comment Share on other sites More sharing options...
modifiedridah2k9 Posted July 28, 2010 Report Share Posted July 28, 2010 I don't really know what you mean? Because your spelling is so bad, i don't know if its "brake" or "break" that you mean. Use full stops instead of commas, its,,so,,annoying,,to,,read,,. Just check its set up square and has a good bleed. Quote Link to comment Share on other sites More sharing options...
Al_Fel Posted July 28, 2010 Report Share Posted July 28, 2010 (edited) Back off children, can you reply to him in Argentinian/Spanish? I didn't think so. A possible issue with your brake could be the grind. When you put the tyre on the rim a lot of wax and rubber from the tyre get on your grind and could cause it to stop working properly. Maybe try cleaning your rim. Edited July 28, 2010 by Al_Fel Quote Link to comment Share on other sites More sharing options...
theom Posted July 28, 2010 Report Share Posted July 28, 2010 I don't really know what you mean? Because your spelling is so bad, i don't know if its "brake" or "break" that you mean. Use full stops instead of commas, its,,so,,annoying,,to,,read,,. Just check its set up square and has a good bleed. Its pretty obvious he means brake... Quote Link to comment Share on other sites More sharing options...
Mark W Posted July 28, 2010 Report Share Posted July 28, 2010 I don't really know what you mean? Because your spelling is so bad, i don't know if its "brake" or "break" that you mean. Use full stops instead of commas, its,,so,,annoying,,to,,read,,. Just check its set up square and has a good bleed. If you're going to get picky about how someone is typing phrases in their second language, you might want to get a bit more familiar with the correct use of apostrophes and capitals in your first language. To the original poster guy - it may be the rim. Some people seem to have issues with them not really working out with their brakes. Quote Link to comment Share on other sites More sharing options...
MATRIAL Posted July 28, 2010 Author Report Share Posted July 28, 2010 OK , thanks for the replies ,now im building another wheel . i will try that , or maibe remove the grind from the viz rim and use tar !. sorry for my bad english ! i hope modifiedridah2k9 can write in spanish as i can do it in english Back off children, can you reply to him in Argentinian/Spanish? I didn't think so. A possible issue with your brake could be the grind. When you put the tyre on the rim a lot of wax and rubber from the tyre get on your grind and could cause it to stop working properly. Maybe try cleaning your rim. It can stop working properly becouse never work properly, you know, when you go up to rear and you wheel slips down, ok thats the situation Quote Link to comment Share on other sites More sharing options...
matt.price Posted July 28, 2010 Report Share Posted July 28, 2010 you have a grind right ? had the problem with my new rim . It took absolutly ages. HERES WHAT I DID .. set up the pads as perfectly square as possible . give it a good re-bleed. and give the pads and more importantly the grind time to bed in. My grind took absolutly ages to bed in , but its good now hope this helps matt Quote Link to comment Share on other sites More sharing options...
modifiedridah2k9 Posted July 28, 2010 Report Share Posted July 28, 2010 OK , thanks for the replies ,now im building another wheel . i will try that , or maibe remove the grind from the viz rim and use tar !. sorry for my bad english ! i hope modifiedridah2k9 can write in spanish as i can do it in english really sorry mate, i never noticed you were spanish :$ my bad, really really sorry Quote Link to comment Share on other sites More sharing options...
craigjames Posted July 29, 2010 Report Share Posted July 29, 2010 I don't know what it is about those rims, but mine was awful. Had about 4 different pads that I tried with it, new bleeds, several different grinds; all tried to be set up by several different people and it was still rubbish. My Rockman/Try-All rim is much much better. Quote Link to comment Share on other sites More sharing options...
matt.price Posted July 29, 2010 Report Share Posted July 29, 2010 Viz square hole rim oh. just re read through it. Andrei Burton told me not to buy a viz rim because your brakes will never work when helping me with picking a new rim . Sorry dude , i think , your stuffed Quote Link to comment Share on other sites More sharing options...
MATRIAL Posted July 29, 2010 Author Report Share Posted July 29, 2010 oh. just re read through it. Andrei Burton told me not to buy a viz rim because your brakes will never work when helping me with picking a new rim . Sorry dude , i think , your stuffed mnn that sucks ,, maibe i took off the grind ( whit a sand paper disc) , and use tar but its a shame use tar with pads like the tnn belaeys or the coust ,, thanks for the reply Matt !! Quote Link to comment Share on other sites More sharing options...
matt.price Posted July 29, 2010 Report Share Posted July 29, 2010 mnn that sucks ,, maibe i took off the grind ( whit a sand paper disc) , and use tar but its a shame use tar with pads like the tnn belaeys or the coust ,, thanks for the reply Matt !! your welcome dude / before buying a new rim ( if thats you want ) try all solutions first. sand it off as you said. try new pads . tar , no tar etc hope this helps Quote Link to comment Share on other sites More sharing options...
mods Posted July 29, 2010 Report Share Posted July 29, 2010 Dont mean to through a spanner in the works, but i had a viz! rim on my ko (3 years ago) and had a hs33 (new) with blue rock pads and it was the best brake i've ever had. Sounds like it may not be bled properly. Quote Link to comment Share on other sites More sharing options...
craigjames Posted July 29, 2010 Report Share Posted July 29, 2010 Dont mean to through a spanner in the works, but i had a viz! rim on my ko (3 years ago) and had a hs33 (new) with blue rock pads and it was the best brake i've ever had. Sounds like it may not be bled properly. That wasn't a Viz! square hole job with angled sidewalls and seemingly made of a material that was awful for holding a grind or actually being ground in the first place. Quote Link to comment Share on other sites More sharing options...
MATRIAL Posted July 30, 2010 Author Report Share Posted July 30, 2010 That wasn't a Viz! square hole job with angled sidewalls and seemingly made of a material that was awful for holding a grind or actually being ground in the first place. i dont understand why its angled ! , you think if i "erase" (sorry but i cant find anoter word) the grind ,, and use tar ,, can work ? ,, If i decide to change my rim ,,who its the best option ? Quote Link to comment Share on other sites More sharing options...
MadManMike Posted July 30, 2010 Report Share Posted July 30, 2010 you think if i "erase" (sorry but i cant find anoter word) the grind You could say "remove" or "smooth off" here mate I can't actually help with your question but thought I'd help you with your English a little... Quote Link to comment Share on other sites More sharing options...
liam n Posted July 30, 2010 Report Share Posted July 30, 2010 i put redbull (energy drink) on my rims . But they were smooth rims so i wouldn't bother Quote Link to comment Share on other sites More sharing options...
rhythm_101 Posted July 30, 2010 Report Share Posted July 30, 2010 (edited) Back off children, can you reply to him in Argentinian/Spanish? I didn't think so. A possible issue with your brake could be the grind. When you put the tyre on the rim a lot of wax and rubber from the tyre get on your grind and could cause it to stop working properly. Maybe try cleaning your rim. i can mira a ver si el freno esta sangrado bien, puede ser que tenga un poco de aire, sino mira si la llanta está contaminado con algo (aceite/grasa etc) esas llantas tienen fama de no aguantar nada, son de mantequilla! asique si cambias de llanta cajete algo con un aluminio mas duro, espero que esto te ayude, y no hagas caso a los tontins del foro!! Edited July 30, 2010 by rhythm_101 Quote Link to comment Share on other sites More sharing options...
Mr Clayton Posted August 1, 2010 Report Share Posted August 1, 2010 have you tried pulling the brake lever? Quote Link to comment Share on other sites More sharing options...
craigjames Posted August 1, 2010 Report Share Posted August 1, 2010 have you tried pulling the brake lever? A highly educational, informative and well thought out response. Well done. 1 Quote Link to comment Share on other sites More sharing options...
matt.price Posted August 2, 2010 Report Share Posted August 2, 2010 i can mira a ver si el freno esta sangrado bien, puede ser que tenga un poco de aire, sino mira si la llanta está contaminado con algo (aceite/grasa etc) esas llantas tienen fama de no aguantar nada, son de mantequilla! asique si cambias de llanta cajete algo con un aluminio mas duro, espero que esto te ayude, y no hagas caso a los tontins del foro!! errrr. bonjour Quote Link to comment Share on other sites More sharing options...
