Mockett Posted July 27, 2010 Report Share Posted July 27, 2010 (edited) put mine on with some deodorant and cant get them off, have any tips?? Edited July 27, 2010 by Mockett Quote Link to comment Share on other sites More sharing options...
l33th3tr33 Posted July 27, 2010 Report Share Posted July 27, 2010 (edited) put mine on with some deodorant and cant get them off, have any tips?? knife? soak them in water? Edited July 27, 2010 by l33th3tr33 Quote Link to comment Share on other sites More sharing options...
stya_bear Posted July 27, 2010 Report Share Posted July 27, 2010 Only method of removal I have heard of is cutting them off Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted July 27, 2010 Report Share Posted July 27, 2010 Wow, didn't know deodorant worked, how much do you put on? Quote Link to comment Share on other sites More sharing options...
Mockett Posted July 27, 2010 Author Report Share Posted July 27, 2010 Wow, didn't know deodorant worked, how much do you put on? just a bit on the inside and it sticks strong, but now i have new bars i cant get it off Quote Link to comment Share on other sites More sharing options...
dannytrialskid Posted July 27, 2010 Report Share Posted July 27, 2010 (edited) Ok this is what I did with mine and it worked. You take out the bar end plugs that goes in your handle bar and then fold the grip from outside of the handle to the inside. It should go into a ball. DO NOT FOLD IT SO IT GOES INSIDE OUT. Basically when you fold it like that it takes of the glue layer. (deodrant layer) Once you have done that fold it back out to normal. Now it should either slide off when you pull it. OR fold it the other vice versa from what you did at the start. Make it into a ball and it will come off. Do you understand? - Don't know if that sounds confusing or not? EDIT: Don't worry it doesn't rip. Along as your careful. Mine didn't rip. Edited July 27, 2010 by dannytrialskid Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted July 27, 2010 Report Share Posted July 27, 2010 Slide a spoke or long thin screwdriver in there and squirt some water in there, rotate and remove Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted July 27, 2010 Report Share Posted July 27, 2010 Slide a spoke or long thin screwdriver in there and squirt some water in there, rotate and remove This Quote Link to comment Share on other sites More sharing options...
Shaun H Posted July 27, 2010 Report Share Posted July 27, 2010 To get mine on or off, I use a pump and an inflatable ball needle. If you pump like crazy the grip should "float" momentarily and you'll be able to incrementally move it off the bars. If you've got access to a compressor I can imagine it being super easy. Quote Link to comment Share on other sites More sharing options...
Luke Dunstan Posted July 30, 2010 Report Share Posted July 30, 2010 Just dipped mine in a mug of water, played around with it, and it just popped off. (using hairspray to stick) Problem being you gotta wait for your grips to dry, but that doesn't take too long with the foams. Quote Link to comment Share on other sites More sharing options...
Canardweb Posted July 30, 2010 Report Share Posted July 30, 2010 Slide a spoke or long thin screwdriver in there and squirt some water in there, rotate and remove What I was about ot say, or spit underneath the grips! I knwo it's disgusting but it works! Quote Link to comment Share on other sites More sharing options...
liam n Posted July 30, 2010 Report Share Posted July 30, 2010 just pull and pull and twist and pull and push the bike stand on the bike and pull and pull and then they'll come off im being serious there maybe aneasier way bt thats what i did with mine it came off in the end Quote Link to comment Share on other sites More sharing options...
