Water/anti-Freeze Bleed
STEVE-0
Is it really a good idea using this in an echo brake?
The brake takes the same type of oil as a magura, mineral, and a magura is proven to work with water/antifreeze mix.
Although that's not to say it won't leak, but I think the newer echo brakes are better for not leaking, providing you clear any swarf from the master cylinder.
