terry_harris Posted July 24, 2010 Report Share Posted July 24, 2010 hi all on my trials bike my rear hs33 i cant think whts wrong with it it bleeds fine with the proper mgura fulid but when i try it on my bike dosent seem to be very powerfujl thought this could be down to the lever so got a new one from tarty bikes but still dont seem to work right any help Quote Link to comment Share on other sites More sharing options...
trials owns Posted July 24, 2010 Report Share Posted July 24, 2010 you could try adjusting the tpa on the lever it could be lazy cylinder pistons, see if they are responsive if not take them out and lube them. the bleed may of got some air in causing it to be weak, when bled was the tpa all the way out? check your tubing on the brake and al the seals to make sure no oil is leaking out. Quote Link to comment Share on other sites More sharing options...
rab shropshire Posted July 24, 2010 Report Share Posted July 24, 2010 could you give us a run down of your setup ie what pads, rim, clamps your running Quote Link to comment Share on other sites More sharing options...
p_ruskin Posted July 24, 2010 Report Share Posted July 24, 2010 Do you have the standard magura pads? Maybe a new set of decent pads would help the bite and power, i recommend any heatsink pads Also bleed your brake with water and it will feel a lot better Quote Link to comment Share on other sites More sharing options...
terry_harris Posted July 24, 2010 Author Report Share Posted July 24, 2010 you could try adjusting the tpa on the lever it could be lazy cylinder pistons, see if they are responsive if not take them out and lube them. the bleed may of got some air in causing it to be weak, when bled was the tpa all the way out? check your tubing on the brake and al the seals to make sure no oil is leaking out. the tpa was wound all the way out mate seem like one side has a lazy cylinder anythig i can do bout this Do you have the standard magura pads? Maybe a new set of decent pads would help the bite and power, i recommend any heatsink pads Also bleed your brake with water and it will feel a lot better im runing the four bolt mounts blue koxx pads Quote Link to comment Share on other sites More sharing options...
rab shropshire Posted July 24, 2010 Report Share Posted July 24, 2010 if you pull the piston out and sparay some wd40 round it that should fix it, but a mildly lazy piston wont make it that much less powerfull Quote Link to comment Share on other sites More sharing options...
terry_harris Posted July 24, 2010 Author Report Share Posted July 24, 2010 if you pull the piston out and sparay some wd40 round it that should fix it, but a mildly lazy piston wont make it that much less powerfull theres no leaks so dont know what it could be though Quote Link to comment Share on other sites More sharing options...
rab shropshire Posted July 24, 2010 Report Share Posted July 24, 2010 as i said above mate what pads, rims, clamps are you running Quote Link to comment Share on other sites More sharing options...
terry_harris Posted July 24, 2010 Author Report Share Posted July 24, 2010 as i said above mate what pads, rims, clamps are you running blue koxx pads ground rim four bolt clamps with booster Quote Link to comment Share on other sites More sharing options...
rab shropshire Posted July 24, 2010 Report Share Posted July 24, 2010 and by not powerfull what do you mean, is it lacking bite/hold or both when your pads hit the rim can you still pull the lever further to your bars? final question are your pads set up perfectly square to your rim Quote Link to comment Share on other sites More sharing options...
terry_harris Posted July 24, 2010 Author Report Share Posted July 24, 2010 and by not powerfull what do you mean, is it lacking bite/hold or both when your pads hit the rim can you still pull the lever further to your bars? final question are your pads set up perfectly square to your rim can you still pull the lever further to your bars?? yep can still do this final question are your pads set up perfectly square to your rim?? yep Quote Link to comment Share on other sites More sharing options...
trials owns Posted July 24, 2010 Report Share Posted July 24, 2010 your bleed is dodgie then because of air inside. also make sure the pads are close to the rim. Quote Link to comment Share on other sites More sharing options...
rab shropshire Posted July 24, 2010 Report Share Posted July 24, 2010 if you can still pull the lever further to your bars then it is a poor bleed, try giving it another bleed and it should be fine Quote Link to comment Share on other sites More sharing options...
terry_harris Posted July 24, 2010 Author Report Share Posted July 24, 2010 can you still pull the lever further to your bars?? yep can still do this final question are your pads set up perfectly square to your rim?? yep where ive got the four bolt mounts on my frame is there anything i can do so i can run a v brke as alot less hassle Quote Link to comment Share on other sites More sharing options...
trials owns Posted July 24, 2010 Report Share Posted July 24, 2010 get a 4 bolt vee brake adaptor on it, they sell some on tartybikes Quote Link to comment Share on other sites More sharing options...
rab shropshire Posted July 24, 2010 Report Share Posted July 24, 2010 you can buy adaptors like these My link are you riding mod or stock, cause if you are on mod there are mormally tyre clearance issues with a rear vee Quote Link to comment Share on other sites More sharing options...
terry_harris Posted July 24, 2010 Author Report Share Posted July 24, 2010 if you can still pull the lever further to your bars then it is a poor bleed, try giving it another bleed and it should be fine it was a shop that bled it as i havent got a blled kit or is there a way of doin it with out thisive got a mod mte Quote Link to comment Share on other sites More sharing options...
terry_harris Posted July 24, 2010 Author Report Share Posted July 24, 2010 it was a shop that bled it as i havent got a bleed kit or is there a way of doin it with out this Quote Link to comment Share on other sites More sharing options...
rab shropshire Posted July 24, 2010 Report Share Posted July 24, 2010 no you need a blled kit im sure someone that rides in your area would give you a hand with it as most riders have a bleed kit. Quote Link to comment Share on other sites More sharing options...
p_ruskin Posted July 24, 2010 Report Share Posted July 24, 2010 it was a shop that bled it as i havent got a bleed kit or is there a way of doin it with out this buy a bleed kit Link 1 Link 2 Quote Link to comment Share on other sites More sharing options...
