TrialsIsHard Posted July 22, 2010 Report Share Posted July 22, 2010 right, i have got a limey 320. Someone told me that you have to run a certain gear ratio because of the space at the rear end of the frame. any advice would be helpful... cheers Quote Link to comment Share on other sites More sharing options...
TRD Posted July 22, 2010 Report Share Posted July 22, 2010 (edited) most mods run 18 front, 12 rear. you'd use a 12 tooth sprocket for a mod most stocks run 18 front, 15 rear. Edited July 22, 2010 by Zoo! Python Rider Quote Link to comment Share on other sites More sharing options...
TrialsIsHard Posted July 22, 2010 Author Report Share Posted July 22, 2010 most mods run 18 front, 12 rear. you'd use a 12 tooth sprocket for a mod most stocks run 18 front, 15 rear. ahh ok, so i'd need a front freewheel 18 tooth... and a 12 tooth rear ? Quote Link to comment Share on other sites More sharing options...
trials owns Posted July 22, 2010 Report Share Posted July 22, 2010 ahh ok, so i'd need a front freewheel 18 tooth... and a 12 tooth rear ? me thinks yes Quote Link to comment Share on other sites More sharing options...
TRD Posted July 22, 2010 Report Share Posted July 22, 2010 get a 18 tooth front freewheel(FFW) and a 12 tooth rear sprocket example: FREEWHEEL SPROCKET Quote Link to comment Share on other sites More sharing options...
TrialsIsHard Posted July 22, 2010 Author Report Share Posted July 22, 2010 cheers dude, i already have an echo freewheel so all i need is the sprocket WIN Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted July 22, 2010 Report Share Posted July 22, 2010 What hub you got? if you can turn the sprocket around so as the teeth are nearest the spokes for more clearance. Quote Link to comment Share on other sites More sharing options...
TrialsIsHard Posted July 22, 2010 Author Report Share Posted July 22, 2010 a monty, ahh good idea the clearance is tight on the limey ! Quote Link to comment Share on other sites More sharing options...
