Help Removing My Cassette.
How Original
OK so I bought the IceToolz cassette remover, I have took out 1 bolt from each side of the bar running through the hub, I have took the cover off, and the spacers and washers and whatnot.
I have put the tool in and put my full bodyweight onto it, but all its doing is clicking, I'm guessing it should be.
But it won't come loose.
Maybe I'm doing something wrong, but can anyone help?
Sounds like you've taken the hub apart?!
All you need is to remove the bolts/QR skewer then use the cassette tool and a chain whip to undo it. Without the chain whip the hub just clicks through it's engagements just as it would if you were riding when you turn the cassette tool, the chain whip holds this still letting you undo the lockring (Y)
