angua Posted July 19, 2010 Report Share Posted July 19, 2010 Right i got a new echo the other day but i cant use it as i need a headset and sanilcams. Im not very good with headsets and i was wondering if this headset would do an echo lite 07 mod Headset link Also i was wondering if anyone could give me direction on snailcams as i have no clue about them. Cheers guy,Angus Quote Link to comment Share on other sites More sharing options...
trials owns Posted July 19, 2010 Report Share Posted July 19, 2010 i got that head the other day and mine wobbles backward and forward, might of been not fitted properly though. Quote Link to comment Share on other sites More sharing options...
isitafox Posted July 19, 2010 Report Share Posted July 19, 2010 Yeah that headset will be fine, what are you struggling with about snailcams?? Quote Link to comment Share on other sites More sharing options...
angua Posted July 19, 2010 Author Report Share Posted July 19, 2010 Yeah that headset will be fine, what are you struggling with about snailcams?? Cheers. Well just what ones to get there are so many different ones.What makes some snail cams better than other etc. Are cheaper ones fine? Quote Link to comment Share on other sites More sharing options...
isitafox Posted July 19, 2010 Report Share Posted July 19, 2010 (edited) No real difference other than an odd few mill difference in how much they can adjust by. The only thing to notice is the Echo SL ones are drilled for a 12mm echo SL axle specifically. Edit: Spelling! Edited July 19, 2010 by isitafox Quote Link to comment Share on other sites More sharing options...
angua Posted July 19, 2010 Author Report Share Posted July 19, 2010 No real difference other than an odd few mill deference in how much they can adjust by. The only thing to notice is the Echo SL ones are drilled for a 12mm echo SL axle specifically. Rightyo Thanks sooooo much:) Quote Link to comment Share on other sites More sharing options...
modifiedridah2k9 Posted July 19, 2010 Report Share Posted July 19, 2010 i got that head the other day and mine wobbles backward and forward, might of been not fitted properly though. Tighten it mate. Angus instead of asking for what one you should buy, ask how to fix your's, cos Adam wouldn't give you a faulty headset. Quote Link to comment Share on other sites More sharing options...
dezmtber Posted July 20, 2010 Report Share Posted July 20, 2010 Tighten it mate. Angus instead of asking for what one you should buy, ask how to fix your's, cos Adam wouldn't give you a faulty headset. he may not have enough headset spacers ? without the correct number it will not clamp the headset Quote Link to comment Share on other sites More sharing options...
saracen1989 Posted July 21, 2010 Report Share Posted July 21, 2010 Cheers. Well just what ones to get there are so many different ones.What makes some snail cams better than other etc. Are cheaper ones fine? regardless of the price dude there all amde of the same stuff ive got viz ones on mine an i made my own set at work wich are just as strong Quote Link to comment Share on other sites More sharing options...
