Echo Bottom Bracket Help...
stya_bear
Hey guys, yesturday I went for a ride and the right hand side bearings for my BB have bust, It feels like a bent set of cranks but I am 100% certain that its the bearings.
Would any of you have a clue as to where I can get replacements as they are sealed... or is it a full new BB situation?
cheers
You can always use the same axle (if it isn't broken) , buy two bearings and use only the outside part (on the inside the axle) and put a spacer in between very tight (the one wich is used for small diameter handlebars and normal stems is ideal). Then the bearings enter in the bb cups perfectly and you get a cheap, lightweight repaired BB. Sorry for my english, I don't know if it's understandable >_<
PD: I've done that with my First BB and now it works perfeclty :rolleyes:
