Mod Chain
isitafox
I've just adjusted the chain on my python as it was drooping quite bad underneath but I'm not 100% sure if I've done it up too tight?!
I can still move it if I touch it lightly with my fingers but it's not quite loose enough to flap on my stays which was really doing my head in before, is this too tight?
It doesn't necessarily have to touch the stays - a few mm is usually fine. Another thing to note is that almost all FFW setups will have a tight point and a loose point, so make sure you adjust your chain for that loose point and it should be fine.
I have a tight and loose point on mine and its really bad. In fact my freewheel skips so often it dangerous. Yea just make sure its not stupidly tight and you will be fine. You should check it every ride. I have to adjust mine nearly everytime. (prob because my fw is so knackered)
