Inner Tube Problem
matthew_coggan
On the last two rides I have been on, I have had my front tube just randomly pop, 1st time i was randomly riding to a new spot and it just popped and went down so quick, 2nd time i had just pedal hopped up a wall and the trye just went down realy fast again, and there was no weight on the tryre at all.
Both tubes were new and had no pathes on them, I am abit conserened as its happened two rides in a row.
Set up is
Trialtech Sport front rim
Echo rim tape
Standard 20 x 1.75 tyre
Monty eagle claw tyre
PSI ruffly 25
Any help and advice welcome
I would suggest checking...
Sharp bits on rim tape.
Any piece of the side of the hole if your rims are holed.
Also worth checking around your valve too.
I had a sharp piece on mine once and as soon as I pumped the innertubes up they went straight back down.
Turned out to be a little sharp bit sticking out on the valve hole.
Hope that helps.
