Rear Wheel Spacing....
cuff86
BMX spacing is 110mm. Trials hubs tend to be made to be 116mm spacing to allow for 3mm each side of cam chain tensioners. Except Monty of course who can be bloody awkward at times! So yeah, basically any hub you can get hold of should work but you may need some spacers/washers to meet the frame depending on your hub and tensioner setup.
