trials owns Posted July 15, 2010 Report Share Posted July 15, 2010 hi, right i have a onza t bird frame with a onza t pro rear hub. so basically i know nothing about snail cams and i want to know how the fit on to my bike/hub. also i was watching the video on tarty and when the chain gets loose do the snail cams click up? so when you want to tighten the chain is it just a matter of clicking it down? cheers Quote Link to comment Share on other sites More sharing options...
trials owns Posted July 18, 2010 Author Report Share Posted July 18, 2010 this may be daft but can i fit some snail cams on my onza t bird? if so which cheap ones? is it just a matter of undoing the axel bolts and sliding them on to the hub? Quote Link to comment Share on other sites More sharing options...
modifiedridah2k9 Posted July 18, 2010 Report Share Posted July 18, 2010 Erm, I'm almost certain that they don't have snail cam bolt holes. You need to drill holes, but somebody will put a video up for you hopefully, as you cant just drill holes, they have to be in the exact bit. Also on my thread you seemed a little interested in the frame, that has snail cam bolt holes already drilled and ready to use. Pm me about it if you want to mate. I'll drop the price Quote Link to comment Share on other sites More sharing options...
trials owns Posted July 18, 2010 Author Report Share Posted July 18, 2010 Erm, I'm almost certain that they don't have snail cam bolt holes. You need to drill holes, but somebody will put a video up for you hopefully, as you cant just drill holes, they have to be in the exact bit. Also on my thread you seemed a little interested in the frame, that has snail cam bolt holes already drilled and ready to use. Pm me about it if you want to mate. I'll drop the price cheers Quote Link to comment Share on other sites More sharing options...
