Choice Of Brakes?
Joe O'Connor
Brakes Ya'll
20 members have voted
  1. 1. What front brake for my Echo Urban 24"?
    • Hope Mono Trial
    • Try-All Disk
      0
    • Other, please specify!
Hey guys,
I'm trying to decide what front brake I should get for my 24" Echo Urban when I get it.
Most likely will be getting it from tarty and I cant decide between Hope Mono Trial or Try-All Disk. Mainly because I dont know about either of them!
What is the difference between the two and what would be the best for me?
I will be doing trials (Obviously) and BMX type stuff (Skate Park etc), basically what the 24" is designed for! XD
Also, is the listing on tarty for the two a set of brakes or just one?
Thanks for the help!
Joe
Edit- Does the Echo Urban need a 27.2mm Seatpost?
And it will have an Echo Rear Hydraulic Rim brake, do I need to get a Brake Booster?
Ta
Edited by Joe O'Connor
Order from Chain Reaction and get a BB7.
Quite a lot cheaper, and I find them much nicer to use and easier to set up.
If you do - note that it doesn't come with a cable or lever. Wilko's cable for £1, and I'd suggest an SD7 lever. Brilliant brake that'll cost you ~£65/70.
This, but i'd go with a linear slic instead of the wilko's cable if your going to be doing bmx riding (spins etc).
The mono trial and try all are the same aside from the lever design/shape and colour scheme. Try-all comes with a try-all design rotor instead of the standard one.
Listed price is for each single brake.
Ive got a BB7 on my CZAR at the moment.
I dont really like it that much. I much prefer the feel of a Hope!
Ive got a BB5 that I could use, but I want to get a real good brake that I can really rely on.
Thanks!
