What To Do With It?
Woodster
i would say sme new pads on the back with a grind, different cranks with a free wheels on the front and fixed sprocket on the back (save weight), maybe some new wheels but if you dont have that money then some bars, stem, new v setup, hope mono on front or maybe a avid bb7.
hope i helped
chris
change the wheels, bb, cranks, and some heatsink yellow cnc v pads for the back with a grind
have a vote :)
Nothing wrong with those wheels at all. Cranks/BB are also fine for the time being. Personally I'd upgrade the forks first, those Onza ones are steel and weigh rather a lot
What I would get would be an 18t bashring, a Tensile freewheel and a 12t rear sprocket. This would improve the engagements and make the drivetrain ride as well as all mid-range stuff. The rear brake could also do with some upgrading, I'd get some pads like the ones that have already been recommended, and in the future a booster, and upgrade the arms, lever and cable.
So aye, basically just a FFW setup, upgrade the rear brake a bit and the forks, bar and stem. Everything else on it is fine IMO. Onza wheels have always been slated, especially the old T-Pro hubs. I always found if you just rebuilt them properly then they'll run forever.
roughly how much do you think that might cost me :) ??
hey forum,
just got an onza bird 2010
click here for pic and description
wondering what could be done to make it better?
thanks guys
woody.
Give the rim a grind, heatsink yellow vee pads are good for the rear, take off the bashplate(save weight + if you hit it too hard, a crack will appear in your frame).
I can't think of anything else. i have had a ride on one, their sweet.
This!
  • Like 1
I wouldn't bother changing the cranks yet, they're pretty good cranks imo.
As others have said, I'd suggest better pads for the back, and a booster seen as they're pretty cheap.
Also I'd suggest new grips, the default Onza grips hurt a lot.
