Box Posted July 8, 2010 Report Share Posted July 8, 2010 I've got some Echo TR mounts that don't need those plastic washers to align. One side is perfectly square, but t'other is slightly on the piss. Has anyone tried filing the tops of the mounts to square things up? Looks pretty straightforward but just wanted to see if anyone had any tips or advice. Quote Link to comment Share on other sites More sharing options...
josh barker Posted July 8, 2010 Report Share Posted July 8, 2010 there meant to be like that until the pads wear in, hence they have no plastic washer to set up with Quote Link to comment Share on other sites More sharing options...
Box Posted July 8, 2010 Author Report Share Posted July 8, 2010 I'm pretty sure that they need to be square ideally... Quote Link to comment Share on other sites More sharing options...
Muel Posted July 8, 2010 Report Share Posted July 8, 2010 Tarty recommend filing the tops of the mounts flat to solve this actually. Just file the mount that is on the piss slightly to make the mount lean over in the correct direction. Then just refit and check how well it has worked, if not, try again. Remember you only need to take off maybe a tenth of a mm each time. Quote Link to comment Share on other sites More sharing options...
Box Posted July 8, 2010 Author Report Share Posted July 8, 2010 Do you reckon it's better to do one set at a time? I saw a vid TNN made where you do the both sets at a time, but couldn't help thinkin that if you started doing it wrong you'd end up messing both mounts up. Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted July 9, 2010 Report Share Posted July 9, 2010 Do them both at the same time, this means you'll get both mounts square to each other and therefore the rim. Quote Link to comment Share on other sites More sharing options...
davey1991 Posted July 9, 2010 Report Share Posted July 9, 2010 there meant to be like that until the pads wear in, hence they have no plastic washer to set up with Don't answer if you don't know. As said above file them both and you'll be fine. Quote Link to comment Share on other sites More sharing options...
pav Posted July 10, 2010 Report Share Posted July 10, 2010 http://www.youtube.com/user/ExpressiveBikes#p/u/6/NEezZeqmVO8 Thank Le from TNN for this, I love him! Quote Link to comment Share on other sites More sharing options...
