Greetings Posted July 7, 2010 Report Share Posted July 7, 2010 (edited) Just installed a few new bits onto the GU. Frame is a BB40 and honestly out of all the Deng frames ever made this is my all time favorite. The geometry is bang on, the frame is very well made, stiff and tough. As for the brakes I haven't tested them properly but they feel completely different to any other brake I've ridden. The levers are tiny but the mechanical advantage must be greater than in Maguras because they flex the frame much more easily. Need to shorten the hose Weight is 8.76kg, not bad for such a heavy frame and rear wheel. Also put away some other goodies, not yet sure if I'm going to use them. Would probably need to change the frame to a horizontal dropout one because I'd need a tensioner with 18:16 gearing on the GU Edited July 8, 2010 by Greetings Quote Link to comment Share on other sites More sharing options...
theom Posted July 7, 2010 Report Share Posted July 7, 2010 Bloody nice is that! Quote Link to comment Share on other sites More sharing options...
mista-neos Posted July 7, 2010 Report Share Posted July 7, 2010 Very nice one of the nicest bikes I seen this year Quote Link to comment Share on other sites More sharing options...
Jamie_Trials Posted July 8, 2010 Report Share Posted July 8, 2010 How much did that cost you And by the way, why have your levers so tilted down? Quote Link to comment Share on other sites More sharing options...
315r Posted July 8, 2010 Report Share Posted July 8, 2010 (edited) Fantastic Bike, I'm between this gu and Zoo piranha, I don't know which prefer. Excuse me but I don't know if I understan it well, Do you want to change this frame for a horizontal drop outs one just because you need a tensioner? Edited July 8, 2010 by 315r Quote Link to comment Share on other sites More sharing options...
Mark W Posted July 8, 2010 Report Share Posted July 8, 2010 Quote - Lever blade design ensures it will provide 14% more power than a standard HS33 2-finger blade. Looks cool though, quite like the feel of Ali's lever as well so hopefully you'll get on alright with them. Quote Link to comment Share on other sites More sharing options...
Greetings Posted July 8, 2010 Author Report Share Posted July 8, 2010 On 7/8/2010 at 9:31 AM, 315r said: Excuse me but I don't know if I understan it well, Do you want to change this frame for a horizontal drop outs one just because you need a tensioner? Yep, to a Slate or something. I hate tensioners with a passion. Never ran them, always had the luck of running the right gear ratio on vertical dropouts. It's fine as it is though, won't be changing anything for now. Quote Link to comment Share on other sites More sharing options...
J Trials 31 Posted July 8, 2010 Report Share Posted July 8, 2010 Looks awesome, glad to see your back into riding! I knew it wouldn't be long. Quote Link to comment Share on other sites More sharing options...
Dan S Posted July 8, 2010 Report Share Posted July 8, 2010 (edited) how does it ride with 158 cranks? Edited July 8, 2010 by Dan S Quote Link to comment Share on other sites More sharing options...
Greetings Posted July 8, 2010 Author Report Share Posted July 8, 2010 On 7/8/2010 at 6:13 PM, Dan S said: how does it ride with 158 cranks? Fine, I've been running these for over 4 years now. The gear ratio is 17:16 so that makes up for their shortness. Quote Link to comment Share on other sites More sharing options...
