t-bird tom Posted July 4, 2010 Report Share Posted July 4, 2010 Hi all My front magura has been leaking for some time now and now, it's just got alot worse, it's leaking from some where, but, i don't know where. So thats why i'm asking you guys, does anyone know how you can find out where it's leaking from? Cheers lads Tom Quote Link to comment Share on other sites More sharing options...
Revolver Posted July 4, 2010 Report Share Posted July 4, 2010 If it's leaking, it means air is getting in as well. So, if you put the brake under water and pump the lever, you should be able to see bubbles coming from somewhere. Quote Link to comment Share on other sites More sharing options...
t-bird tom Posted July 4, 2010 Author Report Share Posted July 4, 2010 If it's leaking, it means air is getting in as well. So, if you put the brake under water and pump the lever, you should be able to see bubbles coming from somewhere. That's a good idea, thanks mate i will try that . Quote Link to comment Share on other sites More sharing options...
