aener Posted July 2, 2010 Report Share Posted July 2, 2010 (edited) Hi. I used to run rubber grips, and loved them. With it warming up, this summer - maybe I'm actually trying stuff I struggle with - but already I was suffering from super-sweat induced slime-grips . I forced myself in to foam grips - didn't like them but the grip was worth it. Trouble is - I don't know how as they seem to last loads longer for other people 'round here, they rip within two or three rides. I've had a go on someone else's Trialtech foams, but didn't really like them. I think they were brand new - do they get nicer with "bedding in", or do they stay like that? Tey felt quite a bit firmer, and might not rip. I don't really like fat grips, either - so I want skinny, foam, rip-resistant grips I think you advisers have your work cut out for you. Any suggestions? Edit: I've just remembered a lot of people rate roadie tape. View points of people who've tried it please? Edited July 2, 2010 by aener 1 Quote Link to comment Share on other sites More sharing options...
Dušan Posted July 2, 2010 Report Share Posted July 2, 2010 i actually have rubber grips which can be locked(inspired grips)and i like them...if i had to change them i would go for foam i used to have them and they were nice to hold but had same problem what i did is that i used electrical tape on it... still nice to hold but without gloves very slippery with gloves it was okay.... than there is laso some kind of cloth tape and that was the best for it in my opinion..... so try this.... or just buy hundreds of them Quote Link to comment Share on other sites More sharing options...
Ryan Trott Posted July 2, 2010 Report Share Posted July 2, 2010 (edited) . Edited May 7, 2011 by Ryan Trott Quote Link to comment Share on other sites More sharing options...
Jackibrap Posted July 4, 2010 Report Share Posted July 4, 2010 Maybe it's time for you to go all foamy i run Trialtech foams, which are great for the summer because it means sweaty palms don't effect my riding. Quote Link to comment Share on other sites More sharing options...
Alle.C Posted July 4, 2010 Report Share Posted July 4, 2010 montys foams are REALLY skinny, to skinny for me though I prefer TrialTech foams Quote Link to comment Share on other sites More sharing options...
Daborn Meister Posted July 4, 2010 Report Share Posted July 4, 2010 Sorry to sort of hijack the thread, but how the hell do you get trialtech foams off?! That's the only problem i've found running them. Quote Link to comment Share on other sites More sharing options...
3dd Posted July 4, 2010 Report Share Posted July 4, 2010 (edited) For me trialtechs are a bit too big. I use rockman thick ones all the time, since I 1st tried them. Lasts me about 2-3 weeks before I change them. But thats when I am riding every day. Trialtech get a bit thinner after a while, still to big for me. So try some of the rockman thick ones or VIz - they are the same diameter. Edited July 4, 2010 by 3dd Quote Link to comment Share on other sites More sharing options...
smithy83 Posted July 4, 2010 Report Share Posted July 4, 2010 i used to ride rubber grips but had some MSC foams come in the shop i work at and ive been running them 2months and still the same as day i brought them,i ride 4times a week so well worth a look Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted July 5, 2010 Report Share Posted July 5, 2010 I want skinny, foam, rip-resistant grips I think you advisers have your work cut out for you. Haha yep, there is nothing that fills that brief unfortunately. Quote Link to comment Share on other sites More sharing options...
Mark W Posted July 5, 2010 Report Share Posted July 5, 2010 Out of all the 'thin' foam grips available, Rockman Thin grips tear the least. Montys are pretty soft, as are Try-All, so if you want a longer lasting one then they're probably the one to get. They are super thin though, although if - like me - you like them like that then it's all good. Quote Link to comment Share on other sites More sharing options...
Alle.C Posted July 5, 2010 Report Share Posted July 5, 2010 Sorry to sort of hijack the thread, but how the hell do you get trialtech foams off?! That's the only problem i've found running them. spray WD-40 between the grips and the handlebar and push with your palms from the inside edge and outwards. When they're of, take away the lub from the foams and handlebar. Before puting them on again, put them in hot water. hope you understand what I mean Quote Link to comment Share on other sites More sharing options...
Simpson Posted July 5, 2010 Report Share Posted July 5, 2010 spray WD-40 between the grips and the handlebar and push with your palms from the inside edge and outwards. When they're of, take away the lub from the foams and handlebar. Before puting them on again, put them in hot water. hope you understand what I mean Yea WD40 on your bar thats a GREAT idea! NAWT! To get them off get a flat head screwdriver between the bar and the grip, pull it up and spray hairspray down there, take the screwdriver out spin the grip with your hand and pull it off. As for grips, trial tech ones are fine'ish, have run them on pretty much all my bikes, the don't really tear unless you fall off at speed (like on my BMX not really trials) You can rip grips very easily if you put them on wrongly. Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted July 5, 2010 Report Share Posted July 5, 2010 Yea WD40 on your bar thats a GREAT idea! NAWT! Actually it's fine, you'd be surprised Quote Link to comment Share on other sites More sharing options...
Mark W Posted July 5, 2010 Report Share Posted July 5, 2010 ProTip: Meths is your friend for getting grips on. WD-40 for getting them off is fine though... Quote Link to comment Share on other sites More sharing options...
aener Posted July 5, 2010 Author Report Share Posted July 5, 2010 Out of all the 'thin' foam grips available, Rockman Thin grips tear the least. Montys are pretty soft, as are Try-All, so if you want a longer lasting one then they're probably the one to get. They are super thin though, although if - like me - you like them like that then it's all good. I do like skinny ones I'll maybe give them a go - cheers Quote Link to comment Share on other sites More sharing options...
Simpson Posted July 5, 2010 Report Share Posted July 5, 2010 WD-40 for getting them off is fine though... Not if your putting other grips straight on? Surely not the greatest of ideas? Quote Link to comment Share on other sites More sharing options...
Mark W Posted July 5, 2010 Report Share Posted July 5, 2010 It's not the end of the world to wipe them, especially seeing as most of it gets absorbed into the grip anyway. Not a million miles different to using GT-85 to put grips on, although obviously that doesn't work with foam grips too well... Quote Link to comment Share on other sites More sharing options...
Alle.C Posted July 5, 2010 Report Share Posted July 5, 2010 Not if your putting other grips straight on? Surely not the greatest of ideas? off course you should take away the WD-40 from the handlebar and grips before putting them on, I don't think anyone is stupid enough to don't ! Quote Link to comment Share on other sites More sharing options...
