Little Yoshi Posted June 29, 2010 Author Report Share Posted June 29, 2010 Ok they confused me. Got a set of forks with no extra mounts. Which one will i need? http://www.tartybikes.co.uk/product.php?product_id=10424&category_id=12 Quote Link to comment Share on other sites More sharing options...
Mark W Posted June 29, 2010 Report Share Posted June 29, 2010 Which forks? Quote Link to comment Share on other sites More sharing options...
Little Yoshi Posted June 29, 2010 Author Report Share Posted June 29, 2010 (edited) 06 zoo!'s Edited June 29, 2010 by Little Yoshi Quote Link to comment Share on other sites More sharing options...
Mark W Posted June 29, 2010 Report Share Posted June 29, 2010 Front, right hand 155mm then I think... Quote Link to comment Share on other sites More sharing options...
Little Yoshi Posted June 29, 2010 Author Report Share Posted June 29, 2010 Any way to run a bigger disk? Im abit of a fat bugger. Quote Link to comment Share on other sites More sharing options...
Mark W Posted June 29, 2010 Report Share Posted June 29, 2010 Either buy a +20mm adaptor and run that with the 180mm Try-All brake, or just run a 180mm, #3 caliper Mono Trial (either standard or carbon/ti, depending on your pimping levels ). If you want even bigger, then a #3 caliper with a +20 adaptor should allow a 200mm rotor. Quote Link to comment Share on other sites More sharing options...
Little Yoshi Posted June 29, 2010 Author Report Share Posted June 29, 2010 Is there any advantage with the ti/carbon? Apart from a few grams shaved off? Quote Link to comment Share on other sites More sharing options...
Mark W Posted June 29, 2010 Report Share Posted June 29, 2010 a few grams shaved off Quote Link to comment Share on other sites More sharing options...
Little Yoshi Posted June 29, 2010 Author Report Share Posted June 29, 2010 (edited) Wat about the hope mono, right hand, 200mm(#3 caliper with an +20adaptor)? Edited June 29, 2010 by Little Yoshi Quote Link to comment Share on other sites More sharing options...
Mark W Posted June 29, 2010 Report Share Posted June 29, 2010 It'd work with your setup, if that's what you mean. Quote Link to comment Share on other sites More sharing options...
Little Yoshi Posted June 29, 2010 Author Report Share Posted June 29, 2010 Aye. You shall be getting a phone call the morrow. Quote Link to comment Share on other sites More sharing options...
