Pistons And Springs?
^Mole^
hi
the way i used to do it with my hs11s was there is a screw above the place that the hosing entre the leaver, undo that then push (hardish )something long and thin down and hopefully the piston will pop out, should be the same on hs33.
hope this
EDIT forgot to say but its obvious but before this take the leaver off.
Edited by trials owns
