Using Snail Cams.
Put bolt in your frame (head on inside)
Put snailcam on axle (take off axle bolts, slide cam on, put bolts back on)
Put wheel in frame with cams on inward/onboard/towards hub side of frame, bolt up.
Then adjust using the tarty guide.
Excellent, cheers dude. i guess they come with the bolts then >_<
Umm... usually your frame does. To be honest you just need a short bolt to go in the hole in your frame, they're only there to give something for the cam to butt up against. Have a look in your tool box/local hardware store for a bolt that'll fit.
