Luke Dunstan Posted June 24, 2010 Report Share Posted June 24, 2010 I'm just building up my T-Pro, putting the Trialtech rear wheel set-up on the frame. and when I go to tighten the 5mm bolts up, they lock, and the wheel just drops out, Think I'm being a tard, but when my snail cams arrive tomorrow, will that fix the problem ( there is a 1mm gap between frame and hub.) Cheers Quote Link to comment Share on other sites More sharing options...
pogo Posted June 24, 2010 Report Share Posted June 24, 2010 If the snail cams dont fix it just use some spacers. Quote Link to comment Share on other sites More sharing options...
Kenny--Trials Posted June 24, 2010 Report Share Posted June 24, 2010 (edited) Are you still running the original onza hub? Because if you are be careful when putting the wheel on again with snail cams because when i did it on my t-pro I went to turn the cranks to align the chain and it forced the axel to snap in half . Edited June 24, 2010 by Kenny--Trials Quote Link to comment Share on other sites More sharing options...
saracen1989 Posted June 24, 2010 Report Share Posted June 24, 2010 I'm just building up my T-Pro, putting the Trialtech rear wheel set-up on the frame. and when I go to tighten the 5mm bolts up, they lock, and the wheel just drops out, Think I'm being a tard, but when my snail cams arrive tomorrow, will that fix the problem ( there is a 1mm gap between frame and hub.) Cheers yeh dude it shoul do just take your time doin it up because the cams tend to slide round Quote Link to comment Share on other sites More sharing options...
Luke Dunstan Posted June 24, 2010 Author Report Share Posted June 24, 2010 Are you still running the original onza hub? Because if you are be careful when putting the wheel on again with snail cams because when i did it on my t-pro I went to turn the cranks to align the chain and it forced the axel to snap in half . No mate. Trialtech hub, had a feeling it was going to be tricky! Quote Link to comment Share on other sites More sharing options...
calum.edwards Posted June 25, 2010 Report Share Posted June 25, 2010 I used snailclamps and that did the trick. Quote Link to comment Share on other sites More sharing options...
davey1991 Posted June 25, 2010 Report Share Posted June 25, 2010 I used snailclamps and that did the trick. Callum new members aren't allowed to buy or sell, hange your signature until your validated then you will be able to without issue. Quote Link to comment Share on other sites More sharing options...
