Tar
Tar can be used to improve braing power. However, the best way to obtain powerful braking effect is to grind a rim. Tar will not provide any extra power during wet weather. The surface becomes wet and it's even worse; while grinding a rim gives you extra kick-ass power.
http://www.tartybikes.co.uk/media.php?group=guides&id=2
I'm guessing you can grind as well as use tar??
Or is that just a bit silly?
Edited by xDUNSTANx
