blaney09 Posted June 20, 2010 Report Share Posted June 20, 2010 just wondering if an avid juicy 5 will be any good for trials Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted June 20, 2010 Report Share Posted June 20, 2010 Should be alright with a decent sized rotor...certainly not as good as a BB series avid or a mono trials though Quote Link to comment Share on other sites More sharing options...
anusthegreat Posted June 21, 2010 Report Share Posted June 21, 2010 If you're about to get a disk brake, consider of buying Hope Mono Trials, the best one available on the thrials market atm. It's all about monocylinder: the main reason it's being used in biketrials. The downhill disk brakes have like 4 or 6 cylinders to prevent a wheel from being stopped at once. You do need that immediate braking power in trials, so, think about spending money for a real thing. Anyway, if your budget is kind of cut, look through the tech specs of the disk brakes you can afford and find the ones with monocylinder. Quote Link to comment Share on other sites More sharing options...
Jemali Posted June 21, 2010 Report Share Posted June 21, 2010 (edited) I think it is nice brake and it will work properly....only problem is that you can't adjust lever travel P.S. one of friend of mine rides on juicy 3 with 160 standard rotor and he is happy=) Edited June 21, 2010 by Jemali Quote Link to comment Share on other sites More sharing options...
anusthegreat Posted June 21, 2010 Report Share Posted June 21, 2010 It's all about your personal trials style'n'stuff you're about to do. If you don't really need that braking power for a gap to front or similar - go for a cheap juicy! Quote Link to comment Share on other sites More sharing options...
JD ZHI Posted July 4, 2010 Report Share Posted July 4, 2010 hi there i have a magura louise no problems with it at all brilliant brake well recomended never let me down Quote Link to comment Share on other sites More sharing options...
