Chain Tight Spot
dann2707
Hey. I've just been riding my local skatepark for a few hours. Now on my return I've noticed that some times the chain is proper tight and sometimes slack, when the wheel goes round. When I'm normally riding down a hill and the chain is whizzing round, I hear some friction like noise and feel it get tighter. Although like now its not acting up but after a while it does it again. Really in need of help! Thanks coxy x
check the rear hub because this happened to me and i took it apart and it was all bent inside the hubshell. it was like an oval shape instead of a curcle. this caused the axel to moove which lead to my chain doing what yours does. have a look and see if thats why :)
Oh, now I'm back at home it appears to be related to the freewheel? I'm spinning my pedals backwards and it comes across a really tight spot which requires more pressure to spin, feels very rough like no bearings. Its a tensile 60.
Thanks for the super fast replies. Proper appreciate it :)
I'm now home and undone the bolts holding the cranks on, they felt really loose :(
And tightened the freewheel as best as I can doing the bodge a screw driver and pedal backwards. Sprayed some luby lube and it doesn't seem to be doing it anymore. See what happens tomorrow.
Cheers again. Coxy x
