crispyboy Posted June 18, 2010 Report Share Posted June 18, 2010 Hello everyone, Had an idea when i was looking at someones bike the other day. could you make a magura 4-finger lever fit a hope mono trial ? If so it would be mental in power Quote Link to comment Share on other sites More sharing options...
crispyboy Posted June 18, 2010 Author Report Share Posted June 18, 2010 anyone Quote Link to comment Share on other sites More sharing options...
dirt jumper jake Posted June 18, 2010 Report Share Posted June 18, 2010 You could probably drill new holes on the maggie lever but the piston is pushed up on a maggie lever whereas on hopes it goes sideways? so i doubt it would work Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted June 18, 2010 Report Share Posted June 18, 2010 could you make a magura 4-finger lever fit a hope mono trial ? No. Quote Link to comment Share on other sites More sharing options...
chris4stars Posted June 18, 2010 Report Share Posted June 18, 2010 i was thinking that putting the effort into setting up the mono correctly or a change of pads would be more worthwhile? not being wide (i never set mine up, it was just how it came from tarty)...my mono locks the wheel without too much effort so the potential is definately there Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted June 18, 2010 Report Share Posted June 18, 2010 Possibly....but if you do then the lever will bite incredibly late, and be VERY far out. Aren't Mono trials adequate in power? Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted June 18, 2010 Report Share Posted June 18, 2010 The old levers fit newer master cylinders and do make the brake a bit lighter (To pull) cos they are a bit longer. Quote Link to comment Share on other sites More sharing options...
