crispyboy Posted June 14, 2010 Report Share Posted June 14, 2010 Hello everyone im thinking of buying these products but i dont know what the performance of them is. What are the trialtech bbs like for strength,lifetime,and overall performance And also the echo sl lever if anyone has brought one as i dont want to spend £100 for something which knowing echo will leak. All help will be good Thanks Quote Link to comment Share on other sites More sharing options...
Jamie_Trials Posted June 14, 2010 Report Share Posted June 14, 2010 Wouldn't bother with the sl lever, had one before, it was powerful but always seemed abit spongy even after about 15 attempts to bleed it Had a trialtech bb too, only used it for about 6 months until i got rid of the bike, never had a problem with it. Quote Link to comment Share on other sites More sharing options...
Duncy H Posted June 14, 2010 Report Share Posted June 14, 2010 In the past I have used an echo tr brake which worked perfectly fine for me even with a water bleed. However that was with magura slaves. The lever shape on the tr's was awesome, most comfiest lever out there and the shape is also on the sl lever too i think. I used an sl brake quite a while back and it seemed to cope ok with an oil bleed. It was never really an amazing brake but that was at a time when I didn't know what I was doing Maybe the newer models are better? My best recommendation would be to get a magura brake and replace the lever blade with an echo sl one Quote Link to comment Share on other sites More sharing options...
Mikey-uk Posted June 14, 2010 Report Share Posted June 14, 2010 I'm sick of everyone quoting the same 'echo brakes must leak' bullshit. Mod Mark used to run them as far as I know and they were fine, he even mentioned somthing about it was only a bad batch that leaked. I've also ridden a bike with an Echo TR (I know its a different brake but same concent) and it was amazing, even without a booster it felt amazing solid. Quote Link to comment Share on other sites More sharing options...
dave33 Posted June 14, 2010 Report Share Posted June 14, 2010 i also would like to know if the echo levers leak with water? i have had the older echo lever and it was goos, only problem was with the tpa kept moving Quote Link to comment Share on other sites More sharing options...
weirdoku Posted June 14, 2010 Report Share Posted June 14, 2010 I hado trialtecho BB since mido marcho. It's still perfecto! Quote Link to comment Share on other sites More sharing options...
