Dan S Posted June 14, 2010 Report Share Posted June 14, 2010 Well, I bought a NEON ISIS cranks....and the point is: I struggled to put them on. (I own RESET TI BB) The right crank (freewheel one) was very tight to fit straight away. So I had to use a soft hammer. Then, the crank had only 4 mm to go to the bb spacer, and basically, I'd pull it with a bolt, but I could not. The RESET bol was to short, and the crank bolts were not wide enough. Usually, my cranks sit 2 mm away from the spacer, and I can't get them further. So, having only 2 mm to go with my Neon crank, I still was not able to pull it with a bolt. The only thing I was told by a seller is that they are "hard to fit", but not "impossible to fit". Neither I was told that the bolts are smaller, or they are not compatible with my BB. So would you consider this "normal", or would you ask for your money back? Quote Link to comment Share on other sites More sharing options...
josh barker Posted June 14, 2010 Report Share Posted June 14, 2010 ride them a bit and just take normal maintanance to make sure there tight, theres no need to get them right to the spacer , there new. It takes time Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted June 14, 2010 Report Share Posted June 14, 2010 (edited) How far on are they? I had tryall cranks on my reset bb and they never went on all the way but were fine. Having said that I was bout to get some of these cranks but am not so sure now. Where did you get them from? Edited June 14, 2010 by Matt Vandart Quote Link to comment Share on other sites More sharing options...
Rafal Posted June 14, 2010 Report Share Posted June 14, 2010 ive got 2,5 years old try all cranks + reset titanium and they still 1mm to the end. So its normal thing. But in the other hand, titanium is weaker so if they will stay too long in this position the axle can be break Quote Link to comment Share on other sites More sharing options...
Dan S Posted June 14, 2010 Author Report Share Posted June 14, 2010 Ok guys, once again. 2 mm is normal for me, but this crank has 4-5 mm. I can't move it either with hammer strikes, or a bolt because bolt is too short and does not reach the axle (though the cranks is 2-3 mm from it's perfect place) I decided to have my money back and get my beloved 158 monty Isis. Quote Link to comment Share on other sites More sharing options...
