angua Posted June 13, 2010 Report Share Posted June 13, 2010 hey Im riding double hs33's and my back wont stop rubbing and it never holds even if i use tar. Im using monty 219XH pads and evo 2 adapters.If anyone could help then please do. Thanks Angus. Quote Link to comment Share on other sites More sharing options...
Dale-Hill Posted June 13, 2010 Report Share Posted June 13, 2010 Try removing the booster and different pads. Quote Link to comment Share on other sites More sharing options...
multi tasking male Posted June 13, 2010 Report Share Posted June 13, 2010 is your wheels buckled ? are they the old evo adapters or new ? if there the old ones like these http://www.magura.com/uploads/pics/zubehoer/EvolutionadapterG_dd4f96_391a6d_01.jpg then there ment to have washers underneath to stop them from moving but if there the new ones then are they set up right ? try pulling the slaves all the way out, have youblead you brake since youv had it ? if you have then there is probably air in there so that will be why the brake isnt working to well. chris Quote Link to comment Share on other sites More sharing options...
Revolver Posted June 13, 2010 Report Share Posted June 13, 2010 If it's always rubbing, the wheel's not in straight, the wheel's dished wrong, the wheel's buckled or the brake is set up shite. If the brake always slips, the brake is set up shite, or there's too much tar, or both. Quote Link to comment Share on other sites More sharing options...
angua Posted June 13, 2010 Author Report Share Posted June 13, 2010 is your wheels buckled ? are they the old evo adapters or new ? if there the old ones like these http://www.magura.com/uploads/pics/zubehoer/EvolutionadapterG_dd4f96_391a6d_01.jpg then there ment to have washers underneath to stop them from moving but if there the new ones then are they set up right ? try pulling the slaves all the way out, have youblead you brake since youv had it ? if you have then there is probably air in there so that will be why the brake isnt working to well. chris I think there new adapters and i think my wheel could be slightly buckled. Iv also bled the brakes three maybe four times but i will do it again. Cheers mate. Quote Link to comment Share on other sites More sharing options...
angua Posted June 13, 2010 Author Report Share Posted June 13, 2010 Try removing the booster and different pads. yeah i got recommened to try rockman cnc blues ? If it's always rubbing, the wheel's not in straight, the wheel's dished wrong, the wheel's buckled or the brake is set up shite. If the brake always slips, the brake is set up shite, or there's too much tar, or both. Well i cant really be the tar because its rubbing even if there is none. Must be set up bad. cheers. Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted June 13, 2010 Report Share Posted June 13, 2010 Im using monty 219XH pads and evo 2 adapters.If anyone could help then please do. That right there is your problem. Quote Link to comment Share on other sites More sharing options...
angua Posted June 13, 2010 Author Report Share Posted June 13, 2010 That right there is your problem. What the pads ? or the evo 2 adapters ? Quote Link to comment Share on other sites More sharing options...
Dale-Hill Posted June 14, 2010 Report Share Posted June 14, 2010 What the pads ? or the evo 2 adapters ? Both, the pads are gash! Do you use a grind or smooth rim? Removing the booster might help with the brake having better hold. Quote Link to comment Share on other sites More sharing options...
