crispyboy Posted June 10, 2010 Report Share Posted June 10, 2010 (edited) Hello everyone, I snapped my lever so i brought a new one and it is really spongy. i changed the spring and seal over from the snapped body to the new one as it was so bad when i got it new. Im running Onza 320 frame phat pads 4 finger lever metal tpa plastic cross over metal main pipe rb booster Ive bled it 7 times and ever time no air comes out Edited June 10, 2010 by crispyboy Quote Link to comment Share on other sites More sharing options...
trials owns Posted June 10, 2010 Report Share Posted June 10, 2010 Hello everyone, I snapped my lever so i brought a new one and it is really spongy. i changed the spring and seal over from the snapped body to the new one as it was so bad when i got it new. Im running Onza 320 frame phat pads 4 finger lever metal tpa plastic cross over metal main pipe rb booster Ive bled it 7 times and ever time no air comes out did u bleed it with oil? Quote Link to comment Share on other sites More sharing options...
crispyboy Posted June 10, 2010 Author Report Share Posted June 10, 2010 did u bleed it with oil? nope water Quote Link to comment Share on other sites More sharing options...
AlexxRogers Posted June 10, 2010 Report Share Posted June 10, 2010 I'm guessing it's going to be your metal hosing, when I had braided hose it went all spongy, try with plastic hose? Alex. Quote Link to comment Share on other sites More sharing options...
craigjames Posted June 10, 2010 Report Share Posted June 10, 2010 Are you saying you've put the old seal and spring in the new seal and spring in the new lever body wasn't right?! Quote Link to comment Share on other sites More sharing options...
forteh Posted June 10, 2010 Report Share Posted June 10, 2010 Sounds like you have a bubble trapped in the lever and bleeding isnt getting it out. Did you rotate the lever on the bars to ensure the bleed nipple was the highest point in the system? Quote Link to comment Share on other sites More sharing options...
