CC12345678910 Posted June 7, 2010 Report Share Posted June 7, 2010 To run a splitter do I need 2 M6/M6 cylinders? Can't see it working otherwise exept using a shroud nut like normal on the M8 side but I don't know how to put the olives onto the hose cos i've never needed 2 before now can someone sort us out please. Ciaran. Quote Link to comment Share on other sites More sharing options...
casualjoe Posted June 7, 2010 Report Share Posted June 7, 2010 If you are using plastic hosing just use the m8 shroud nut fitting, its pretty easy, much easier than banging a barb into a hose. You could use m8/m8 or m6/m6 or m6/m8, your choice. Quote Link to comment Share on other sites More sharing options...
CC12345678910 Posted June 7, 2010 Author Report Share Posted June 7, 2010 (edited) How do i get the olive on? Buy blocks and tap it on with a hammer, right? EDIT: BTW i don't won't to buy new cylinders. At the mo i have a standard set up. Edited June 7, 2010 by CC12345678910 Quote Link to comment Share on other sites More sharing options...
casualjoe Posted June 7, 2010 Report Share Posted June 7, 2010 The olive just slides on, it clamps onto the hose as you tighten the shroud nut. Quote Link to comment Share on other sites More sharing options...
CC12345678910 Posted June 7, 2010 Author Report Share Posted June 7, 2010 (edited) how cums the one that came off my dead main hose won't go back on then? and the ones i've got are gold and silver not black like the ones on tarty They both came out the same shroud nut as well when i've been told there should only be one in there. i'm Confused.com Edited June 7, 2010 by CC12345678910 Quote Link to comment Share on other sites More sharing options...
casualjoe Posted June 7, 2010 Report Share Posted June 7, 2010 because its been clamped before, you can pry it open with a flat head screwdriver or buy a new one. Quote Link to comment Share on other sites More sharing options...
CC12345678910 Posted June 7, 2010 Author Report Share Posted June 7, 2010 thats answered 1 question. Thank you. Quote Link to comment Share on other sites More sharing options...
CC12345678910 Posted June 7, 2010 Author Report Share Posted June 7, 2010 Cheers people. mod can close now. Quote Link to comment Share on other sites More sharing options...
