Rim Grinds
Billy-C
  On 6/5/2010 at 8:06 PM, Jord said:
Is this as simple as it sounds?
Just grinding the braking face of the rim. To aid stopping power?
And what disks do you use?
Yes it really really is, well obviously you have to be carefull to pull the disk not push it and you also have to watch the angle of the disk.
You use metal cutting disks.
Thanks Bud.
And why Cutting disks, Over proper Grinding ones?
Only thing i can think of is the 'Harshness' of actual grind?
  On 6/6/2010 at 10:50 AM, Jord said:
Thanks Bud.
Yer they give a harsher grind but this is why you pull the disk if you push it they cut into the rim.
