TrialItAll Posted June 1, 2010 Report Share Posted June 1, 2010 Heeya, I have mashed my BB and am looking in to buying a new one. Does anyone know the BB length of an Adamant A3 Short? I know I should remove my BB and look but I don't have the tool to do it with, but it's being ordered Many thanks, Harry. Quote Link to comment Share on other sites More sharing options...
josh barker Posted June 1, 2010 Report Share Posted June 1, 2010 any length bb, or do you meen the bb shell of your frame if so its a 68mm shell and for the bb axle length either 122 or 127.5 will do fine Quote Link to comment Share on other sites More sharing options...
psycholist Posted June 1, 2010 Report Share Posted June 1, 2010 If the current BB is the right length you don't need to remove it from the frame to get all the measurements you need from it. Taking the cranks off will allow you to measure the BB axle length (If it's an ISIS and you don't have the cranks off, measure the axle length you can see and add 32mm (ISIS splines are usually 16mm long if my memory serves me correctly) to get the total axle length. The BB shell length is the length of the tube the BB is screwed into in the frame and will be 68 or 73mm on most bikes. If you're happy with the chainline and crank clearance on your current setup buy the same size BB again... Quote Link to comment Share on other sites More sharing options...
