riper115 Posted May 29, 2010 Report Share Posted May 29, 2010 (edited) can u tell me how to bleed hs33 please ty cheers seth soz i carnt speel Edited May 29, 2010 by riper115 Quote Link to comment Share on other sites More sharing options...
PeanuckleJive Posted May 29, 2010 Report Share Posted May 29, 2010 haha, bleat.... Use the search function? There's a million guides to do it. Water bleed it, water is awesome. 1 Quote Link to comment Share on other sites More sharing options...
Revolver Posted May 29, 2010 Report Share Posted May 29, 2010 I made a water bleed tutorial. Quote Link to comment Share on other sites More sharing options...
matthew_coggan Posted May 29, 2010 Report Share Posted May 29, 2010 You can do it the same was as a normal blead just with water. Quote Link to comment Share on other sites More sharing options...
theom Posted May 30, 2010 Report Share Posted May 30, 2010 http://www.trials-forum.co.uk/wiki/Bleeding_Magura_brakes Quote Link to comment Share on other sites More sharing options...
crashbanggg Posted May 30, 2010 Report Share Posted May 30, 2010 I downloaded a manual off the magura website to do mine and used a bleed kit, which has everything you need to do the bleed, and costs about £20 off tarty bikes Quote Link to comment Share on other sites More sharing options...
side hop shaun Posted June 1, 2010 Report Share Posted June 1, 2010 Do it in a sick undo the bolt on the lever and the one on the slave using co-ordination and some logical thinking cover one hole at a time with your fingers and use the lever as a pump! im sure that you will work it out Quote Link to comment Share on other sites More sharing options...
