t-comp-kierz Posted May 29, 2010 Report Share Posted May 29, 2010 Hi i have a rear onza hub and when i was out riding today it started making weird noises then it was really hard to move the wheel it can move its really stiff. Has this happened to anyone else and how do i fix it Kieran Quote Link to comment Share on other sites More sharing options...
Maxie_Monty Posted May 30, 2010 Report Share Posted May 30, 2010 Hi i have a rear onza hub and when i was out riding today it started making weird noises then it was really hard to move the wheel it can move its really stiff. Has this happened to anyone else and how do i fix it Kieran There will be a nut at the edge of your frame on the inside next to the hub, that will adjust the bearing tightness of the hub, could try loosening the bearings. Make sure your pads aint rubbing either, you never know lol. Quote Link to comment Share on other sites More sharing options...
t-comp-kierz Posted May 30, 2010 Author Report Share Posted May 30, 2010 The pads are deffenetly not rubbing that was the first thing i checked Quote Link to comment Share on other sites More sharing options...
