modifiedridah2k9 Posted May 28, 2010 Report Share Posted May 28, 2010 Hey, Quick question, how do you do 180 degree hops, i can only do 90 degree, im tailwhiping 90 degrees and hoping 90 but i want to hop 180, do i need to tailwhip 180 in order to do this?? Thanks to all. Quote Link to comment Share on other sites More sharing options...
rab shropshire Posted May 28, 2010 Report Share Posted May 28, 2010 obvious answer, but spin further lol when spining turn your head and look at where you want to land at, doin this will turn your shoulders and the rest of your body will follow Quote Link to comment Share on other sites More sharing options...
trials owns Posted May 28, 2010 Report Share Posted May 28, 2010 before u do a endo turn the wheel sharply then snap the brake in, that should get u further. use pedal kick with 180 hops its hard to get the hang off but u will eventually get it. Quote Link to comment Share on other sites More sharing options...
modifiedridah2k9 Posted May 28, 2010 Author Report Share Posted May 28, 2010 Thanks for the replies so far guys cant go try these because it peeing down rain outside Quote Link to comment Share on other sites More sharing options...
Nick Manning Posted May 28, 2010 Report Share Posted May 28, 2010 I don't think this has what you after, however it does have other tricks on there which might help you in the future. Trash Zen Quote Link to comment Share on other sites More sharing options...
konstant Posted May 28, 2010 Report Share Posted May 28, 2010 Try twisting your body in the opposite direction that you plan to spin and crouching. Turn your head as far round as possible and jump up to start the spin. It's all about how you coil up your body... feels a bit unnatural at first but even with a flat spin you can get well past 180 degrees Quote Link to comment Share on other sites More sharing options...
psycholist Posted May 31, 2010 Report Share Posted May 31, 2010 Pretty much what people have said already - just like to hop upwards you have to push into the ground, for a spin you have to twist the opposite way to the direction you want to turn to preload for the spring in the direction you want. Still working on getting the front wheel to land where the back wheel was and the back where the front was though, I always tend to spin slightly more around the back wheel than the centre of the bike, so I land almost a foot behind where I took off from. Quote Link to comment Share on other sites More sharing options...
Jakob S. Posted June 2, 2010 Report Share Posted June 2, 2010 Basicly everything you need is to see this: Vids say so much more then words.. Quote Link to comment Share on other sites More sharing options...
