Magura Louise Disk Rubbing ?
Ashley Sayers
when i spin the wheel it makes a rubbing noise , wen im on it its not as loud but still makes the noise :/
ive had a look and the disk is closer to the one pad than the other ?
cheers
is the disc bend in one place?
or is it constant rubbing?
Edited by zoo python luke
Undo the caliper bolts slightly, then pull the lever. This should centralise the rotor.
With the lever still pulled tighten the bolts.
If it is still rubbing,
the pistons may need pushing back
mounts may need facing
system could be 'over bled'
